Upconvert VI Requests
@hd83 wrote:
Could you please convert the attached files into version 8.0 for me (the files are zipped)? I am not sure what version these files were made from, but they were last modified in 1995.
They were done in LabVIEW 3.1. You'd have to wait to see if somebody still has LabVIEW 4 (which I think can open it), or has the Conversion Tool.
Is it this?
EDIT: I see Gerd already answered your question.
Message 141 of 1,261
(1,949 Views)
Yes, I just found the newer corresponding files in the device drivers section.
Thanks!
Message 142 of 1,261
(1,942 Views)
Can somebody help me with converting those files into Labview 8.2 (they are in Labview 5.1)?
Thank you 🙂
Message 143 of 1,261
(1,909 Views)
Hi olgaz,
here they are in LV7.1!
Whatever that 6KTimeDelay does, it doesn't look ok for me Smiley Wink
Message 144 of 1,261
(1,905 Views)
Hi Minx,
here it is in LV7.1. You will have lot's of fun with this beast of stacked sequences Smiley Wink
(following up this question...)
Message 145 of 1,261
(1,874 Views)
Thank you!
The file is supplied by the manufacturer of the motor I am working with now. It does its job well enough, so I guess it is ok - maybe ugly, but ok...
Message 146 of 1,261
(1,851 Views)
Hi Steffen,
here's the upconverted version of your VIs...
Message 147 of 1,261
(1,805 Views)
I wonder if someone could please convert this LabVIEW 5 library to drive an LCR meter to LabVIEW 9 please?
Many thanks
Chris
Message 148 of 1,261
(1,772 Views)
Hi Chris,
here it is in LV7.1. You should clean up and use features of newer LV versions...
Message 149 of 1,261
(1,770 Views)
Hi Gerd,
Wow, that was fast!
Thanks Smiley Happy
Message 150 of 1,261
(1,763 Views)
