Update file name
Hi Nishant,
It is no problem to continue with the questions within this thread.  😄
I do not understand what you mean by the "big header".  I did look at you attached file and it is basically a text file with ".xls" extention.  It also opens nicely in Excel.
Are you talking about all the formatting header placed by Excel when you save it using Excel?  Actually, depending on the Excel version (especially recent ones), the data is in binary format.  And you can't easily manipulate it as a text file... You could use Active X... but before I suggest anything, I need to better understand the issue.
Remember: Anything is possible 😉
Does your data file look exactly like the attachment?  Or is the attachment an example of what you want to achieve?
Ray
Message 31 of 94
(3,347 Views)
Hiii, Ray
                   By the word big header I want to say that, when we are using the one header option in the write LVM file, it shows the header like i ve shown you in the attached xls file with this message, but i don't want that kind of big header and i only want the header of the kind i ve shown in the pas xls file, but i couldn't do so, i can't attach that kind of header while using the write LVM file, i only can do that while using write to spreadsheet file or write character to file, etc. so thats wat i mean by the big header problem.
Nishant
Message 32 of 94
(3,348 Views)
Hi Nishant,
I am looking at your attached example, and I am not sure that I understand (early morning 😉  )
Is this what you are trying to achieve?
LabVIEW Measurement
Writer_Version    0.92
Reader_Version  1
Separator           Tab
Multi_Headings   No
X_Columns        One
Time_Pref          Relative
Operator    nishant
Date          1/17/2006
Time          17:08.4
***End_of_Header***
Message 33 of 94
(3,335 Views)
Hiiii, Ray
        No I am not trying to achieve this, instead i dont want this kind of header, which also i can do but the main thing is can i add the header of the kind that i attached in the previous xls file and i only want that kind of header more than anything else, so is it possible to add that kind of header, while writing the data into the xls file with Write LVM.vi.
Nishant
Message 34 of 94
(3,327 Views)
Good morning Nishant,
By prevoious example, do you mean this one?
Date
Time
CH-1
CH-2
CH-3
CH-4
CH-5
CH-48
You do realize that you can open / create the xls file  (or any type) in a previous step, meaning that you could have a sub-vi that opens or creates the file and you could even create the header at that time.  Then you close the file until you need to write to it.  The trick is to pass an index to the next vi (or sub-vi) so that you know where to start writing data to ( index the write location ).  That way, you can create any header because it is outside the "Write LVM.vi".
Let me know how it goes..
Ray
Message 35 of 94
(3,315 Views)
Thanks Ray,
          I came to know something out of it like, first creating the header through open/create excel file and then after passing the pointer to another vi, where we will write the data into the same excel sheet, in which we have wrote the header? am i right? i think this way, my problem might be solve, but what about the index in the excel sheet coz it should also know that from where in the excel sheet data should be written, another thing is i want the increasing file name while write the data, which is easily available by Write lvm.vi, that's why i am preferring the write lvm. vi, so whenever new file will be created, i ve to create the header inside it, that also might be somewhat difficult, so please suggest me something that way.
Nishant
Message 36 of 94
(3,310 Views)
Hi Nishant,
Yes, it is along those lines..  What you can do is create a sub-vi which creates the new file and immediately appends a header.  When completed, it returns a value for where to start writing data.  Or better, place that value into the header info, for later use.
You might also consider a static value for where to start writing data if & only if the header info is static in size & content... but storing the pointer (location value) in the file itself is the safest approach.
Ray
Message 37 of 94
(3,304 Views)
Way to go Ray!
I suggest you change your name to "JobLabView"
The only time I stick with a topic that long is when there is  P.O. in place.
Ben
Message 38 of 94
(3,284 Views)
LOL!!  Ben!!
How are you?
I've been sneeking into the forum between sw releases... And as you can probably tell, I've been releasing a lot 😄  and posting, too!
Seems like the Breakpoint is quieter...
Wishing you a good weekend, buddy!
Ray
Message 39 of 94
(3,279 Views)
Nishant,
Have a look at the attached vi's.
I cleaned it up a bit and fixed a bug when using a hardcoded folder (directory).
The vi will now create the file and header.
Ray
Message 40 of 94
(3,273 Views)
