Upgrade computer
Dear Sir/Madam,
We wish to upgrade our computer from windows Xp to the latest system, due to current PC may breakdown anytime. Therefore we need to advise which type of PC is suitable for to purchase? We are using LabView 8.2 for our tensile machine.
Message 1 of 15
(5,502 Views)
Accepted by TNL
Can i suggest calling national instruments customer sales team they will be able to advise you further
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 15
(5,480 Views)
Thank you, i shall the the sales team 🙂
Message 3 of 15
(5,473 Views)
Hi TNL,
May I know what is your OS after upgrading?
Attached is the system requirement for the LabVIEW 8.2.
Since 8.2 was released for quite sometime now (and it's quite old too), the spec needed to run 8.2 is quite low. So what I suggesting is you read the file I attached and I think you should use the spec of the latest OS instead. No use if you can use the LabVIEW but the whole thing drag you down.
Cheers
SR
Message 4 of 15
(5,423 Views)
I forgot the attachment Smiley Very Happy
Message 5 of 15
(5,422 Views)
Hi, thanks for the information. I already call the sales person. They advise me to upgrade LabVIEW to latest version. OS windows 8 or 7 can support LabVIEW 8.2? I will go through the attachment later.
Message 6 of 15
(5,413 Views)
You an refer to this link: https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
Its about windows version compatibility with LabVIEW.
Cheerz,
SR
Message 7 of 15
(5,368 Views)
Thanks for the information 🙂
Message 8 of 15
(5,352 Views)
No problem bro.
Message 9 of 15
(5,349 Views)
We have problem when loading the software, it always freezing, kindly refer to attached file. Is this problem cause by software or the computer itself? I think we need someone to check our system.
Message 10 of 15
(5,300 Views)
