Use scripting to create numeric control without inc/dec button
I'm having fun using scripting to do things that were formerly "impossible", such as creating a cluster programmatically from a list of variable names and their associated types (to be used in a subsequent program).
When I create a numeric control on a Front Panel, it has the Increment/Decrement button visible, by default.  I wanted to create controls without this feature, but I couldn't figure out how to do this (or even if it is possible, though I don't see why not).
Any ideas?
BS
Message 1 of 9
(3,995 Views)
Create it, then set its Increment/Decrement Visible property to FALSE.  This property is specific to digital numerics, so you need a digital numeric reference to make it work.  The property is all the way down on the end of the list.
Message 2 of 9
(3,994 Views)
1.  You should really be using the System Numeric, no such problem.
2.  I will often create a custom control and use instances of that instead of starting from scratch.  In this case it is a simple change, but later you may want several tweaks in the controls you place.
Message 3 of 9
(3,987 Views)
Interesting idea -- I'd never used the System controls (I'm a "Modern" guy).  That would work, but it is curious that the Inc/Dec property, which is present when the control is actually placed on the Front Panel, doesn't seem to be available when creating the control with a script.  [Of course, I could create a Numeric Indicator {Modern}, which works until I change the "control" to a Control].
Message 4 of 9
(3,976 Views)
Good thing I read this three or four times before writing my snarky reply!
When I created the new VI Object, I made it a Numeric with style Numeric Control (modern).  When I scrolled down the list of properties, they stopped with Unit Label -- in particular, Increment/Decrement Visible wasn't listed.  Of course, if I just "lay down" a numeric control, this property is visible.
So I played around a little more. I saw somewhere a reference to the "Numeric Object class", and you refer to "digital numerics" (??? aren't all numeric "digital"?), so I went looking.  I found a sub-class of Numerics called NamedNumeric -- not sure what that is, exactly, but what do you know, it has the Increment/Decrement Visible? property!
Time to give it a try ...
BS
Message 5 of 9
(3,972 Views)
Accepted by Bob_Schor
Right above the Named Numeric menu item is the one you are looking for: Digital
Use Digital for the Class constant and Numeric Control for the Style.
Message 6 of 9
(3,969 Views)
???  I now know that Named Numeric is wrong (gives me a 1057 error).  I'll try "Digital" after dinner -- I trust you are right, but being a native Californian, I have to "Trust, but Verify".
So how do "Numeric", "NamedNumeric", and "Digital" vary?  [I'm beginning to see that Numeric is a "level up" the Class Hierarchy, and therefore might not have all of the "specialized" Bells and Whistles ... ooooh, and Digital is just that class that has finger-like (base 10?) numbers as part of the control (i.e. Sgl, Dbl, I32, etc).  Now I get it!
Thanks for the help.  Off to dinner, then a test, then (probably) an Accept as Solution!
Message 7 of 9
(3,963 Views)
The menu reflects the underlying class hierachy.  The name of a pull-out menu (and the top element in that menu) represent a parent class and the other menu items are for the children.
All of them are Numeric.
Some of the Numerics are Digital and others are NamedNumerics.
Enums and Rings are types of NamedNumerics which are types of Numerics which are types of Controls which are.....
Message 8 of 9
(3,952 Views)
Yes, indeed, that worked!  Haven't (yet) had dinner (cooking as I type), but I was eager to find out if this does the trick, and it does!  Thanks, Darin and DF, for the speedy (and helpful) responses.
BS
Message 9 of 9
(3,947 Views)
