User32.dll Causing Error on Application Exit
Yes that clears up what you last said. Also I'd like to add that it works the same if you just put the name of the dll in the dialog box without the full path as someone suggested above. It won't be copied to the application directory this way either.
Thanks for your help.
Message 11 of 11
(559 Views)
