Showing results forย
Search instead forย
Did you mean:ย
Using Chart.js in LabVIEW NXG Web Module
Hi everybody,
    Chart.js is a simple, clean and attractive set of JavaScript charting tools based on HTML5 technology.Chart.js provides you with a complete, interactive Chart that is easy to integrate into your website.
    Attached is a demo program I wrote to illustrate how to use chart.js in LabVIEW NXG. If you like, you are welcome to download and use it.
Note: this code is written in NXG5.0. hope you enjoy it๐Ÿ˜€.
(4,608 Views)
Hi๏ผŒimpressive work!
       I have learned your way to write content into HTML place holder, but nothing happens, can you give me some suggestion?
 This is the code I put in Javascript:( I had change id to "window')
function test()
console.log('test of id');
var id = document.getElementById("window");
console.log(id);
id.innerHTML = "java test";
(4,318 Views)
Nice work ๐Ÿ˜Š !
Could you show an example of to use other chart types like:
Line, bar, column, doughnut and pie? ๐Ÿ™‚
________________________________________________
"Science is about knowing, while engineering is about doing"
(4,270 Views)
