Using One Property Node For Multiple Controls/Indicators
Question for all you LabVIEW gurus.  Is there a way to create 1 property node that is used for multiple indicators?  For example, if I wanted to display the same value on 10 different indicators using the property node - value function do I need to create 10 separate property node-value instances for each indicator?  Or is there a way to tie all of those indicators to only one property node?
Thanks!
(4,038 Views)
Well, usually you use an array of references to all those indicators and an autoindexing FOR loop with your single property node inside…
(4,031 Views)
Accepted by hobby1
Hi hobby1
You could create a cluster, and inside in it put all the indicators, see the image attached
(4,029 Views)
Thanks guys for the help.  Both those methods do the job Smiley Happy
(4,017 Views)
