Using a true Boolean to increment a counter
I'm also not seeing a need for the second loop.  That sounds like it is just adding unneeded complexity.  Just use the shift register to hold your cound and increment it when your peak detection triggers a TRUE value.
Message 11 of 19
(2,567 Views)
I understand what you guys are saying but I'm a litlle confused on how to pull it off.
Message 12 of 19
(2,560 Views)
isn't this the same question as last time post? bool crossing will take care of your dwel time and count just once....again, we don't know your application and sampling rates, there are many different ways to get the same results  Smiley Wink
Message 13 of 19
(2,558 Views)
I have this which is close, but still not exactly what I need.
Message 14 of 19
(2,534 Views)
Message 15 of 19
(2,534 Views)
Actually now I figured out how to do it, thanks everyone for the help with the shift registers instead of trying to use two loops!
Message 16 of 19
(2,505 Views)
would this work?
Message 17 of 19
(2,503 Views)
Wow, I can't believe I didn't notice this was the same question I responded to a day or two back.  Getting old... Smiley Sad
I made this little VI to show you the simple way and it's pretty much the same as Apok's solution but he added the DAQ code and mine has some nice bells & whistles in case you want to get fancy.
Message 18 of 19
(2,490 Views)
ahhh...well no.If your value is above your set point and dwells more than the loop iteration, your case statement will add those count. Bool crossing eliminates that and counts only at the crossing and not during the dwell period above the set point.
edit: and i failed to recognize your bells and whistle  Smiley Very Happy
Message 19 of 19
(2,485 Views)
