Using and deploying Image functions without Vision RTE
I wrote and compiled a program to open an image and convert the image to an array.  The program uses only non-Vision RTE functions (by design).  When I create an installer and deploy it, I get an error from the program trying to locate NiVisSrv.dll and NiVision.dll.  I did not add additional installers when creating the installer project (in addition to the LV 8.5 RTE).
I added the two missing dlls to the installer and loaded them into windows/system32, and the program loaded but I'm concerned that the license requirement for the Vision RTE will kick in and I'll have unhappy customers.  Additionally, the program runs but does not display images when opened.
I have the Vision library installed on my development PC but I don't want to have to install the Vision RTE (for $400 per exe) when I'm using the functions included with standard LV8.5 (i.e. those functions that come with LabVIEW that doesn't have the Vision library).
Any help is appreciated...
Message 1 of 16
(9,236 Views)
You should put NIVision.dll and NIVisSvc.dll into the installer and have the appropriate vision run time licence to have the image processing function work on your exe. "Image to array" is definetly one function from the vision development module.
Message 2 of 16
(9,206 Views)
@muks wrote:
 ..."Image to array" is definetly one function from the vision development module.
to muks:
Wrong answer. IMAQ Image to Array is free (and also included in VAS). (Otherwise IMAQ Array to Image is not free.)
to SJT:
if you have message that Vision is not licensed, it means that you have at least one function, which should be licensed. Check all functions used in your application. Deactivate Vision license on your development PC, then check error out of vision functions. The non-licensed function will return to you error "non licensed" or something like that.
Also be sure that you have folder PlugInControl in \Shared\LabVIEW Run-Time\x.x on the target PC. (I don't remember if this folder will be deployed by standard LabVIEW Run-Time installer or by Vision RunTime Installer).
Message 3 of 16
(9,197 Views)
Andrey - thanks for the reply.  I developed the program to use only standard functions included in LV8.5.1 (nothing from the Vision Development Module (VDM)).  But I do have the VDM installed on my development PC.  When I create the installer, "Additional Installers" does not have VDM checked, so it does not get installed on the target PC and there is no activation prompt, etc.
I have included the two missing DLLs in the installer and saved them to windows\system32.  The program found them but still did not display the image.
As part of my troubleshooting, I included the IMAQ 4.0 Installer and the program worked but it added an additional 60 steps to the installer and I don't know if it will eventually require activation as if I had installed the VDM...
I will try de-activating the VDM on my development PC and check for the plugin folder.  Thanks for your help.
Message 4 of 16
(9,181 Views)
Andrey - I compiled the program and created an installer on a PC that does not have the VDM.  I deployed it to a clean PC (no NI stuff installed).  The NIVision.dll and NiVisSvc.dll were missing when I ran the program.  I moved these manually to the system32 folder and the program operated but did not display the image in my front panel display window (it displays correctly on the develpoment PC).  I did not receive any errors from any of my vision functions, so I don't think the Vision RTE is necessary.  Is it possible that the program is operating in a 30-day window and I'll have customers complaining 30 days after installation??
The folder PlugInControl was not created in \Shared\LabVIEW Run-Time\x.x
So I need to find a way to get the display to work.  Does it something to do with dependencies in the creation of the EXE or installation files?
Message 5 of 16
(9,134 Views)
Message 6 of 16
(9,129 Views)
Message 7 of 16
(9,121 Views)
I created a sample VI with the same problem.  All functions are standard.  LV projects are included to create an EXE and Install the program.  I manually loaded the two vision dlls.  I've included screen grabs from the development and target PCs to show the display behavior problem.  Any help is greatly appreciated...
19989i03DEB22FD6B255EB
19993i6820469D14819A58
Message 8 of 16
(9,101 Views)
I already point above that you have missing PlugIn folder in Run-Time folder - this is the reason. These files not included into standard LabVIEW Run-Time. They will be deployed with Vision RTE or IMAQ. If you want to avoid both in your installer, then you have to include these files into your own installer manually.
Also its not necessary to have two different projects for application and for installer - you can combine both in single project. It very convenient to have both - application builder and installer within same single project.
Well, step by step:
First you have to put all support files in your project. I will create INSTALL virtual folder where I will put links to all files which are necessary:
In system32: NIVision.dll and other Vision DLLs. Take a note, that I have Vision 2009 on my PC, so there are five files. If you have older version, then you may have less files (I don't remember which files was added in latest version) - see what you have in your System32 folder. Also take a note that I have included tbb and tbbmalloc (Intel threading libraries) required for Vision. They may be not necessary for older Vision versions.
Also I have included into project "missing"  files from LabVIEW Run-Time. They are present on your development PC.
So, the project looks like this:
20021i74A49B302EDCB41C
For better understanding - file view:
20023i4FFB887EDA1192A3
Well, now go to installer. I just should put files into according folders on the target machine:
20025iD8060B5B08D78965
Attached changed project (because it contained fixed paths, some changes may required)
Hope it helps,
Andrey.
Message 9 of 16
(9,095 Views)
Andrey - This worked very well.  Thanks for taking the time to help.  Also, thanks for the tip on combining EXE and INSTALL projects.
Message 10 of 16
(9,074 Views)
