Using class (oop) on a RT Target?
Is there any way to use a class in code running on a FP?
I have a broken arrow telling me that this type of data (object I presume) are not supported on the target (FP2000, will become a cFP-2100 soon).
I'm using LV8.2
Thanks!
Vincent
(5,436 Views)
From this link (an object-oriented programming FAQ) there is this information:   (https://www.ni.com/en/support/documentation/supplemental/06/labview-object-oriented-programming-faq....
4. Do LabVIEW classes work with LabVIEW Real-Time or any non-desktop target?
In LabVIEW 8.2 and later, LabVIEW classes do not work LabVIEW Real-Time or any non-desktop target.
-Bob
(5,355 Views)
"With LabVIEW 2009, object orientation is now supported on LabVIEW real-time targets. Object-oriented programming is not supported in real-time with LabVIEW 8.6 and prior."
(3,775 Views)
Hi Vincent,
Additionally, LabVIEW Real-Time 2009 will not run on an FP-2000 controller.  Refer to this document for more information https://www.ni.com/en/support/documentation/compatibility/17/real-time--c-fieldpoint-controllers-and....
(3,744 Views)
