Using command prompt to control labview program without opening it
So I jsut wrote a labview programm I wanted to know how can I control some of its function without opening it.
It's already in an .exe foramat
Message 1 of 18
(4,873 Views)
For control on start use Application:Command Line Arguments Property.
If you want control during working, you can use ini/xml file for write/read parameters
Message 2 of 18
(4,850 Views)
Thank you for your response.
Sadly I didn't find the example in my LabVIEW folder.
May I ask you if you could upload one ( one for example where you activate a function or button that is in LabVIEW.exe program from the cmd).
Message 3 of 18
(4,835 Views)
Thanks you but sadly I couldn't open it as my version is11.0.1 and yours 16.
Message 5 of 18
(4,823 Views)
Accepted by topic author 77maxmustermann
Message 6 of 18
(4,811 Views)
Thanks you man I implemented it in my program and it work BUT when I use the command one other time with a different value it doesn't always change it why is that?
Message 7 of 18
(4,802 Views)
Make a simple "not working" example.
Message 8 of 18
(4,800 Views)
For example the program you gave me if I rapidly change the value of numeric it wont change every single time. the first time it'll always work after that sometimes it work sometimes it don't
Message 9 of 18
(4,797 Views)
Nvm the problem I was just too fast.
Last question I have a integer that I gave a default value meaning it wont change even when use the cmd any tip for that?
Message 10 of 18
(4,791 Views)
