Using iteration number as time on graph
Woh, your code isn't verry clean, I suggest to read Labview beginnings to learn rules of programmation...
Sorry, I use a French version of Labview, but I joined the vi. You can do the custom X axis of your choice, this is an exemple :
V-F
Message 11 of 13
(641 Views)
Sorry about the sloppy code, like I said I was in the middle of integrating that example VI I found and I wasn't planning on showing anyone else my code.
I think you are misunderstanding what I want to do. Changing the display format to use time codes will only use real-time.
I want to use my x value data as simulated minutes, as the simulation returns results hundreds of times faster than real-time.
Message 12 of 13
(629 Views)
If I well understand what you would like, your while loop executes each 0.05s, and you want this time represents 1 minute on your XY graph ?
In this case, just multiply by 60 the X-Value input of sub-vi "Graph as chart"
I hope it will help you.
V-F
Message 13 of 13
(615 Views)
