04-19-2011 03:24 PM - edited 04-19-2011 03:26 PM
Woh, your code isn't verry clean, I suggest to read Labview beginnings to learn rules of programmation...
Sorry, I use a French version of Labview, but I joined the vi. You can do the custom X axis of your choice, this is an exemple :
04-19-2011 04:18 PM
Sorry about the sloppy code, like I said I was in the middle of integrating that example VI I found and I wasn't planning on showing anyone else my code.
I think you are misunderstanding what I want to do. Changing the display format to use time codes will only use real-time.
I want to use my x value data as simulated minutes, as the simulation returns results hundreds of times faster than real-time.
04-20-2011 01:06 AM
If I well understand what you would like, your while loop executes each 0.05s, and you want this time represents 1 minute on your XY graph ?
In this case, just multiply by 60 the X-Value input of sub-vi "Graph as chart"
I hope it will help you.
