Using "file dialog" box to select several files
Hi!
I'm using the "file dialog" box to get the path of several files (set to not be limited to one file). If I select only one file, it works fine. If I select several, it says that it can't find the path of the first selected file (see pics).
Anyone has a solution ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,606 Views)
Hi zyl7,
if i use it like you i get no error. See my attached example.
Mike
Message Edited by MikeS81 on 05-26-2008 10:44 AM
(2,604 Views)
Thanks for that fast answer. Observing your VI, I noticed that the only difference is that in your code you do not precise the "start path"... i removed it in my application, and it works... So it looks like the dialog box doesn't like when the files to select are not in the same folder described by "start path"... weird...
(2,598 Views)
Hi zyl7,
i´m not sur about that. If i connect a start path and change the path where i select the files a get no error.
Mike
(2,589 Views)
