VI Problem using LV8.2, Vision Builder for AI 3.0
Dear All,
I have problem that that some vi are missing while I upgrade LV and Vision bullder for AI.
Origional: LV7.1 & Vision bullder for AI 2.0
New: LV8.2, Vision Builder for AI 3.0
I don't konw why the error happen. Please give advice for me.
Thank You
(3,314 Views)
Hello HeartShield,
If you double-click on each missing subVI error, you should be taken to a location on the block diagram where a question mark is holding the place of the missing subVI.  Right-click on the question mark, select Replace, and then navigate through the palettes until you find the VI.  Clicking on the VI in the palette completes the replace operation for that question mark.  After repeating this procedure for each missing subVI error, you will need to save your VI.
Best Regards,
T. McCarty
(3,280 Views)
