VI backwards compatibility with older run-time Engines
I currently developed a VI in Labview 8.6.1.  I also created an exe for it so that I can run it on another computer.  However, the other computer has an older version of the Run-Time engine installed and so my program cannot be executed on that computer without upgrading the run-time engine to 8.6.1.  But....that computer also has some programs that run on that version of run-time engine.  I have two options here but I do not know the effects or how to do it.
1) Install a newer version of the run-time engine (8.6.1) - Will this break the current functionality of the programs already on it?
2) Is it possible to have my VI run on older versions of the run-time engine?  If so, how do I do that?
Thank you.
(3,800 Views)
Installing a newer version of the runtime engine is your only option and it will not overwrite older version or have any affect on programs that use a different runtime.
(3,794 Views)
Accepted by Gormander
As dennis said simply install the new runtime engine. We have machines that have 5 versions of the runtime engine on them and we haven't experienced any problems.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,788 Views)
Thank you all.  I was hoping that it was ok since they give you options to include multiple run-time engines when you create an installer package.
(3,786 Views)
