VI documentation
Hi Everyone,
There’s there’s few things that NI teach you when you want to create a sub-VI.
Two of those things are include you code into an error case structure and include documentation in the VI properties.
I personally working on a project with several thousand VIs and I spend lot of time documented the diagram plus the VI.
So to spend my time, I develop a package to quickly Vis.
-The principle is to include all the documentation you want to add to your VI into the subdiagram label of the error case structure of your subVI.
-Connect all the inputs/outputs to your terminal.
-Then use the quick drop shortcut “ctrl+space then crtl+c”
- Your VI is documented with your comment and the names of your inputs and outputs.
You need to have already installed jki openG package.
The code is open source. Enjoy.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 1 of 26
(8,804 Views)
Merci Sabri 🙂
Jovan N. - Application Engineering
Message 2 of 26
(8,640 Views)
De rienSmiley Wink
Message 3 of 26
(8,615 Views)
I Love This!
Share that on the Community Side as well but, (There is always room to improve right?) Use Silver Error In and Error Out for consistancy and get the wired terminals on the root diagram (See Here)  You probably want a NaN output in the Error in case anywaySmiley Wink
Nice work!
Message 4 of 26
(8,578 Views)
Hi
Message 5 of 26
(8,526 Views)
Accepted by topic author sabri.jatlaoui
Done!
Quickly creating VI documentation
Message 6 of 26
(8,460 Views)
Awesome!
I think this would be appreciated over at the quick drop enthusiast page as well. You may also find some other plugins you want to use.
https://decibel.ni.com/content/groups/quick-drop-enthusiasts
Message 7 of 26
(8,396 Views)
Thx for the link Jacobson, I'll add my link asap.
Message 8 of 26
(8,351 Views)
Looks and works pretty good from what I've seen. When I'm documenting I also usually include in their as well the date of the documentation and a list of TYPDEF/CTLS that are used in the block diagram.
How hard would it be to include these aspects in the self-documenting as well? Other then that looks pretty amazing, and will definitely prove faster than other methods.
Message 9 of 26
(8,286 Views)
Hi ogk.nz ,
Thx or the advice, I'll definetly include the datein the next release. I already include te list of the controls connected to the connector pane.
Wat i'll do for te next update, it's include the documentation of the ctl and their type. For the cluster, I'll define all the data contain inside.
Do ou tink it will be a good change?
Regards.
Message 10 of 26
(8,278 Views)
