usb stepper motor
Hello every one....
Iam doing one project it consists stepper motor...so i would like interface this stepper motor to labview programming...can it possible....for this reason i would like to buy usb driver stepper motor......so any other modules needed?
(3,982 Views)
Hi hanumeshbujji
Yes you can interface stepper motor with LabVIEW using the proper hardware.
You will need the following:
1. A Stepper Motor
2. A power supply rated at the stepper motor specs
3. A stepper motor driver that connects to the motor, power supply, and controller (such as the ones mentioned below)
4. A controller which is usually a USB DAQ or a myRIO that has digital outputs (if you are familiar with NI hardware)
5. A software written in LabVIEW that sends digital signals to the digital outputs according to the desired speed/direction (normally pulse and direction)
6. Some basic internet search skills becuase there are zrillions of posts on how to do all the above Smiley Wink
Good Luck
AA
(3,942 Views)
thank you.....Smiley Happy
(3,930 Views)
