VI to search for specific character & check to be Integer
Hello all, i apologize if this has been asked before.
I have come up with a simple VI to grab specific characters from a string.
However I want to go 1 step further, which is to ensure that the characters are integers and not other characters.
I have no luck so far to get my VI to perform that extra task, so is there anyone who can advise me?
I have attached the current VI that I am using now.
Thank you.
JonKang
(2,990 Views)
|testres=[0-9]+ Verify FOE_Y  in value,
(2,976 Views)
The character that I am looking for is after the ","
Example: this is the whole string that I receive
BCNF|id=xxxxxxxxx|testres=8016 Verify FOE_Y in value,-4|testres=8017 Verify FOE_X in value,-2|
The 2 values I need to grab and verify are the '-4' and '-2'
So far I am able to get the numbers but I am stuck with the conversion between string & integer.
Thank you
(2,941 Views)
Hi Kang,
Those values are missing in your example…
Where are you stuck?
Your VI already contains a conversion from string to numeric data, but you aren't able to use this function???
I would search for "Verify" in your input string, then parse the next string to determine either FOE_X/FOE_Y. With the remaining string I would use ScanForString with "in value,%d"…
(2,934 Views)
Well, you didn't say you want to grab them. You only mentioned search and check...
Use Decimal String To Number to convert the string to integer.
But why not use a Scan From String? It's much cleaner and safer then two match patterns. The format string would be:
BCNF|id=%[^|]testres=%d Verify FOE_Y in value,%d|testres=%d Verify FOE_X in value,%d|
That would give you a string, and 4 integers (extract the bottom to 5 outputs):
BCFN|id= matches the literal string
%[^|] matches anything but |
testres= matches the literal string
%d matches any integer
Verify FOE_Y in value, matches the literal string
Verify FOE_X in value, matches the literal string
(2,926 Views)
