VISA_ARDUNO_CHANNEL WIRES
My project is attached. Thanks
Message 21 of 27
(949 Views)
I give up!  There is no working LabVIEW program to examine in the file you attached.  I cannot provide any more help.
Message 22 of 27
(930 Views)
I attached a .zip file which must be uncompressed with winrar. Inside just open PROJECT.lvprj thats all. I have Labview 2017. 😞
Message 23 of 27
(927 Views)
I wouldn't you have attached a true zip file that could be unzipped and opened with native Windows file explorer?
EDIT:  Actually it is a true zip file that can be opened with Windows Explorer.  It is missing a subVI called "Loop Frequency.vi".
I do see a problem in VISA Read Multiple Channels, where you are using "Bytes at Port" which is wrong 99% of the time.  You send a command "z", then immediately check Bytes at Port and try to read that many bytes.  I bet it is 0.   How fast to you think your device is that it could read the command and respond back with a full message before your PC moves onto checking the number of bytes?  A quick fix is to put a wait in there before checking the number of bytes.  The real fix is to use a real serial protocol that has a defined number of bytes, or ends with a termination character.  Why don't you read 14 and throw away "bytes at port" since you define that a valid message as a length of 14?
Also, no need to wire all of those index constants on Index Array. By default they'll be 0, 1, 2, 3, .....
Message 24 of 27
(916 Views)
Thank you for the reply.
I actually send from Arduino a termination character '\n', do I have to modify termination character when I initialize serial port?
I will try your fixing options, when I have searched in internet about serial protocols I havent been lucky. I just have experimented with it.
Loopfrequency.vi... I dont remmember but the main vi its there.
Well thank you so much. I hope Bob could open the zip file 🙂
Message 25 of 27
(907 Views)
The default for a VISA serial initialization is to enable the termination character and set it for \n (line feed, AKA new line).  I don't see where you initialize the port in your code so I don't know if you did something different.
Message 26 of 27
(894 Views)
Yes. I inicialized serial port with termination character '\n'.
The last values I send from Arduino are 13 and 10 --> '\n'.
I did tried what you suggested me but the frequency does not go higher than 250 Hz. With my code it gets 1000 Hz...I really dont know why...I am a noob on serial communications.
Message 27 of 27
(869 Views)
