VISA Find Resource output to VISA Open
VISA Find Resource returns an array of strings. When I wire one of the elements to VISA Open there is a coercion dot.
Is there a function that should be use so that the coercion dot goes away?
(2,911 Views)
Accepted by nyc_(is_out_of_here)
Try attached.  You can ignore the dot in this case as well.
Kudos and Accepted as Solution are welcome!
(2,910 Views)
Thanks. Keep forgeting about TypeCast.
(2,904 Views)
That is not necessary. Wire the string directly and ignore the coercion dot. It causes no harm at all and is probably more efficient.
(2,898 Views)
I agree with that.
(2,893 Views)
What about using the conversion VI here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Default-Data-Function/idc-p/1084787#M4535
I think it'd be safer than using the typecast, but I'm not sure about any speed difference.
(2,884 Views)
