traditional DAQ labview 11 windows 7
Hello everyone.
 I have many programs that uses DIO config VI to run motors etc. However I have upgraded to LV 11 on Win 7.
If I install traditional DAQ will those programs still work on my windows 7 64 bit OS ...
Please advice
Thank you
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,463 Views)
NI-DAQ and LabVIEW Version Compatibility (for Windows)
You really should consider upgrading the VI's to use DAQmx.
(2,462 Views)
Ok I agree. But keeping the algorith of the program same. I can still replace traditional DAQ vi with DAQmx vi's right ?
Like Portconfig replaced with DAQmx createchannel and DAQmx start task.
If I do that its gonna function properly right.
Abhi
Abhilash S Nair
LabView Gear:
(2,460 Views)
(2,456 Views)
Thanks a lot!
Abhilash S Nair
LabView Gear:
(2,452 Views)
