VISA Find Resource output to VISA Open
VISA Find Resource returns an array of strings. When I wire one of the elements to VISA Open there is a coercion dot.
Is there a function that should be use so that the coercion dot goes away?
(2,902 Views)
Accepted by topic author nyc_(is_out_of_here)
Try attached.  You can ignore the dot in this case as well.
Kudos and Accepted as Solution are welcome!
(2,901 Views)
Thanks. Keep forgeting about TypeCast.
(2,895 Views)
That is not necessary. Wire the string directly and ignore the coercion dot. It causes no harm at all and is probably more efficient.
(2,889 Views)
I agree with that.
(2,884 Views)
What about using the conversion VI here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Default-Data-Function/idc-p/1084787#M4535
I think it'd be safer than using the typecast, but I'm not sure about any speed difference.
(2,875 Views)
