VISA Read y=f(t) graph
Message 11 of 16
(967 Views)
Please show your read buffer in hex display…
Message 12 of 16
(945 Views)
Here it is :
Message 13 of 16
(937 Views)
Hi Trainee,
your values are separated by a CR (0x0D), not by LF (0x0A).
Change your scan string accordingly!
Message 14 of 16
(935 Views)
Thanks again. How can I know if it is separated by CR or LF?
Message 15 of 16
(932 Views)
Hi Trainee,
The first place to look at is the manual of your device. There you should find all the details of data communication…
If that fails you can look at the received data - as I did. Then compare the (hex) data with an ASCII table of your choice!
Message 16 of 16
(926 Views)
