Variable reluctance sensor signal simulation
Hi Developers,
I recently started working on a project  to simulate several sensor signals, it is a Hardware In the Loop testing system, I need to simulate a variable reluctance speed sensor signal, the signal is a sinusoidal with 24 pulses per revolution, one pulse has a lower amplitude than the other 23 pulses, I found in other old post a VI which generate a sine wave that is multiply but a square wave with a duty cycle calculated based on the number of missing teeth, so while square amplitude is zero sine is multiplied by zero and We get the pattern for a crank shaft sensor, instead of that the signal I need has one pulse with a lower amplitude, any idea on how I can do this, maybe generating a sine wave counting zero crossing and every 24 pulse multiply sine amplitude to have one pulse lower than the other 23??? I am pretty new using labview HIL suite and the PXI system with RTOS and FPGA module, any info or help will be appreciated. Thanks
(4,101 Views)
Usually there are two input variables , position and speed, both have an influence on your reluctance sensor output.
One possible FPGA approach: First look-up table  for position to du/dv value , followed by a multiplication with speed.
Greetings from Germany
Henrik
LV since v3.1
(4,060 Views)
Accepted by caesarken
here is one quick solution for a simple 'simulation'   ..
edit : the vi posted creates two versions since I don't know how your signal looks like. maybe a starting point, shown is just one ..
Henrik
LV since v3.1
(4,057 Views)
Hi Henrik, thank you so much for your help, based on the VI you shared and a VI I found in an older post from 2005, I developed a new VI that generates the signal I need, signal has 24 pulses per revolution, 1 pulse has a lower amplitude than the other 23 pulses, It has a linear behavior for the amplitude respect to RPMs, I attached the VI I generated and the VI I found in addition to the one You shared. Any comment or idea to create a more efficient VI will be appreciated. Also an image of the signal generated below. Thanks again.
(4,033 Views)
