Verify a DAQmx Task is a particular type of task
I'm trying to find a method in LabVIEW to verify that a DAQmx Task contains a particular type of task.  For this particular application, I want to verify that a DAQmx Task is a Digital (Line) Output before executing it.
Regulating the IO Filtering of a DAQmx control is an option for me, but this code will be used by other programers and I would like to add this extra check w/ error handling in the event that the Task to does verify to be of the correct type.
Thank you for your input.
-Nic
(3,158 Views)
You could use the DAQmx Channel Property Node and read the ChanType property. If it's the Digital Out of a line, Digital Output
Message Edited by Broken Arrow on 12-22-2009 11:49 AM
Richard
(3,151 Views)
Accepted by hecmar.arreola
Use the Channel Property-> Channel Type property node and it will tell you what type of task it is.
Cheers, Matt
Message Edited by mtat76 on 12-22-2009 11:48 AM
Message Edited by mtat76 on 12-22-2009 11:49 AM
(3,150 Views)
Ah ha!  Thanks you guys!  Didn't occure to me that a DAQmx Task can be fed to a DAQmx Channel property node.
(3,142 Views)
