Verify if a path exist or if its not a path
I want to read data from a spreadsheet file in a part of the application I am building but to read this data I want to verify first if the path exists or not, since I only wnt to read this data if there is such a file. I was trying to use a function called "Path type" which returns 2 if the path wired is 'Not a Path' but its not working properly, its acusing if the path is valid or not, not acusing if it exists in the computer or not.
I appreciate your help,
Lucas
Lucas Faquim
(3,833 Views)
Accepted by Faquim
That's why the Check if File Or Folder Exists.vi is there (look in the File IO->Advanced palette.
(3,827 Views)
(3,826 Views)
