Version Madness
I want to have a VI that runs OK under LV 2018, but if loaded with LV 2020, will have additional capabilities.
The tricky part is linking to code that contains features that aren't in LV 2018.
Here's what I've tried: The sub VI that contains the new features is saved in LV 2020.
The main code, saved in LV 2018, has the call to that sub VI inside a type specialization structure.
It works OK, except that a warning message always pops up when the main VI is loaded.
Is there any way to suppress the "File version is later ..." messages for a SubVI in a declined case in a type specialization structure?
Attached are snippets that illustrate what I'm trying to do.
Load "Main Merge (lv 18).vi" with LV 2020+, and everything is OK.
Load it with LV 2018 or 2019, and everything is OK, except for the warning messages.
Message 1 of 10
(3,642 Views)
Accepted by paul_cardinale
What about a dynamic call ?
It's a bit slower, especially on first call, but that works:
 Also there are considerations when building into an exe or ppl. The "Sub" must be included in builds for versions >= 20.
Message 2 of 10
(3,591 Views)
Message 3 of 10
(3,519 Views)
I'm not sure if this works, but you could give it a try.
Instead of opening a VI reference, buffering it and then do a call by reference, you could use the VI, and right click it, Call Setup, select Load and retain on first call.
That should theoretically do the same, but I'm not sure how that will turn out when the DUT is a different version.
If it works, it will save a bunch of code.
Message 4 of 10
(3,447 Views)
Strange stuff I have never tried but possible in theory.
Build the 2018 exe version with "allow future versions of the RTE" then simply Uninstaller the 2018 rte and only permit the 2020 rte.
I once asked about how LabVIEW determines which rte to use when an exe with that setting exists on a machine with concurrent valid rtes .  The answer was rather surprising. I don't recall the details and I never had to use it myself.  (Frankly, I worked hard to AVOID ever getting into that viper nest) But there should be a setting in myapp.ini or something to say use xxxx, yyyy, zzzz in that order of preference.
Message 5 of 10
(3,392 Views)
As a side note, you can use the attached VI to determine what RTEs are installed.
Message 6 of 10
(3,375 Views)
"Get Installed Software.vi" is missing.
Probably depends on Daqmx?
Message 7 of 10
(3,311 Views)
Only following this topic because of the unusual approach I downloaded your VI and ran it in LV 2021 and the front panel return nothing.
No error, no data. Nothing. Not even the root function:
Message 8 of 10
(3,308 Views)
Two suggestions.
May be NI System Configuration is not installed or wrong, try to download and reinstall:
https://www.ni.com/en-us/support/downloads/drivers/download.system-configuration.html#
Or may be because you have LabVIEW installed in German.
Message 9 of 10
(3,287 Views)
Everything's fine in the MAX. And I don't think it's because of the german version. Never mind, don't need that information right now.
Message 10 of 10
(3,279 Views)
