‎08-26-2012 11:30 PM
How to change from latest version to previous version
For example
I created a project by naming it as version 1.
Later my colleague edited the same project and named it as version 2.
Now with help of labview can i extract the files of version 1 ? And compare the difference between Version 1 and version 2 .
‎08-27-2012 12:24 AM
‎08-27-2012 12:59 AM
Version control is a whole different system where you can see the older versions depending on your check-out and check-in. Here in LabVIEW you have two options Source control and version History and I believe it can be linked to a Version control tool but how it works am not sure about that. You can search in NI and can find some useful information.
‎08-27-2012 01:10 AM
Hello Dennis_Knutson & P Anand Thanks for you reply
I dont have any version control system . can i have the link for pro pro version please @ Dennis_Knutson
‎08-27-2012 10:06 AM
You obviously already have LabVIEW so I don't understand what sort of link you are looking for. If you have the menu option that I mentioned, you have the pro version. If you don't, you would have to upgrade.
‎08-27-2012 10:09 AM
And if you want to know what version control system you can use, please read the hundreds of posts that have already been posted on this: http://forums.ni.com/t5/forums/searchpage/tab/message?q=version+control+for+labview#message-list
‎08-27-2012
10:14 AM
- last edited on
‎06-05-2026
12:00 PM
by
Content Cleaner
Maybe she/he should browse to this collection of whitepapers.
Norbert
‎08-27-2012 10:27 AM - edited ‎08-27-2012 10:29 AM
Hi!
Since you are not using version control tools, you can place the two versions of the sw in two different folders and use the compare tools of labview, for instance Tools->Compare->Compare Hierarchies.
If the project was simply renamed (i.e. there's no Version 1 backup), I'm afraid the old version is lost forever,
and that's why you should use a version control software.
Marco
