Voltage vs. Time help
No.
Look at terminal configuration in the task.  It will say either differential, RSE,  or NRSE  (for referenced and non-referenced single ended.)
Message 11 of 16
(1,652 Views)
I had it set at default, and I also changed it to RSE but that did not change anything.
Message 12 of 16
(1,628 Views)
One clarification question: when you're referring to the graph showing a constant, are you referring to a LabVIEW front panel graph, or are you referring to the DAQ test panels in MAX? I assume that those are avilable even in DAQmx Base?
Message 13 of 16
(1,626 Views)
I am referring to the Front Panel waveform graph.  DAQmxbase is not compatible with MAX.
Message 14 of 16
(1,621 Views)
Also, incase you're not able to take a look at my VI because it was created using DAQmxbase, here is a picture of my setup.
Message 15 of 16
(1,615 Views)
When you are getting the samples from the DAQ channel, why have you used the Nchannel Nsample vi when you only have one single channel ?
Message 16 of 16
(1,591 Views)
