Waveform Chart Digital Display Blinks 0.00
@Ben wrote:
I was never able to come up with a example where NI could duplicate the issues.
I did yesterday morning since I started noticing the blinking "0" on one of my VIs.  It is somehow related to having a waveform data type for the chart.  I was unable to get it to reproduce with a scaler or array data type.
VI saved in 2016, but I confirmed the issue in 2018 SP1.
Message 11 of 22
(2,572 Views)
Hey @Crossrulz,
I also recreated this in LabVIEW 2018 SP1, so I'll go ahead and let R&D know. Is this affecting a VI you are developing?
Chase
NI Technical Support Engineer
Message 12 of 22
(2,527 Views)
As a followup, we have documented this in CAR 278457
Chase
Message 13 of 22
(2,508 Views)
Curiously, [i] is always 64 when the stop occurs. Might be a hint. 😄 In fact all iterations where the zero occurs is always at the same iterations: 64, 149, 184, 231, ...). Tried no wait, 1ms or 5ms wait.
Maybe some numerologist can see a pattern 😄
Message 14 of 22
(2,494 Views)
And here's a picture if the delta(i) between zeroes. Looks like an EKG. Fully repetitive:o
Message 15 of 22
(2,492 Views)
OK, this is very confusing, because it seems to depend on other factors. While the values seem to be always the same on the same computer, the result are quite different on another machine:
AMD Ryzen 1700x: 64, 149, 184, 231, etc....
Dual Xeon: 158, 189, 213, 169, 282, etc....
This makes no sense. I wonder if the values change after a reboot, for example. Here's the xeon pairwise difference. Note that the period is now 18 samples long. (was 13 on the AMD)
I wonder what others are getting... 😮
Message 16 of 22
(2,467 Views)
i7-4790
Message 17 of 22
(2,453 Views)
Shouldn't some relation to the GPU's refresh rate be expected?
Hide the chart, and you'll get a straight line.
Not sure how that's related to the type pf the data. Also, I'd expect Synchronous Display to make a difference, but it doesn't. Nor does the size of the chart. The chart history length does make a difference.
Message 18 of 22
(2,430 Views)
Do things change if you run Prime95 in parallel?
Or have something else utilising the UI thread?
Message 19 of 22
(2,423 Views)
Just to give this a bump...I am still seeing this bug in LabVIEW 2021.  I do think Christian is on to something.  Using the VI I posted earlier, the error always occurs on iteration 50.
NI did give us a CAR number.  But since NI no longer uses the CAR database, do we have a new Bug number to reference?
Message 20 of 22
(1,828 Views)
