Waveform Chart Scale
Hi, Everyone.
I want to use Waveform Chart and want to create "Scale menu".
I'm already try it but it's not work...
Can someone help me fix this VI?
Thanks!
Message 1 of 12
(6,999 Views)
Accepted by Vindecua
A few points:
  • You don't need to use the local variables - just wire the value from the existing terminal
  • The outer case does nothing
  • Only one Y scale will be visible, even if both plots are selected - the visible plot is determined by the X Attitude control. Is this intentional?
  • Both your plots are on Y Scale 1 - right click on the graph to change this (under Plots tab).
  • All of your axes have autoscaling enabled, which is creating flicker. If you're setting the scale manually, turn off autoscaling.
  • Your plots are difficult to see due to the small values and large ranges - this is presumably because you replaced the real data acquisition with a random number generator so viewers can run the VI (thanks!). Consider multiplying them by some value to make it take up a larger fraction of the range.
Message 2 of 12
(6,984 Views)
hello butcher ,
What is a use of Active scale property ?? could you explain me pls
Message 3 of 12
(6,961 Views)
Message 4 of 12
(6,957 Views)
Can anyone explain about the importance of active scale property node ??
Message 5 of 12
(6,950 Views)
Copying from the Context Help window:
Gets or sets the active or current Y-Scale of a graph or chart. Call this property before setting other properties on a specific scale.
That is - when you set other properties (like Visible, or Min/Max), the values are set for the Active Scale. This is altered by writing to the Active {X,Y} Scale property.
Message 6 of 12
(6,941 Views)
Thanx a lot Mr.butcher . !! what is the  common input we have to give for this Active property node . ? sometimes its throws a error ?
Message 7 of 12
(6,934 Views)
Just give it a number of which Y scale you want to sets.
but you have to duplicate Y scale first.
Message 8 of 12
(6,928 Views)
I finally success, but now i have a new problem.
How can i split all plots's scale sepelately?
Can someone help me?
Message 9 of 12
(6,910 Views)
You can't dynamically create new scales, but if you already used the duplicate menu to create them you can use the Active Plot and Plot > Y Scale index to set which y scale a plot appears on.
Message 10 of 12
(6,908 Views)
