Waveform Graph input data type
Waveform graphs do not change input data type according to wire. When i create new graph it is set to double data type and does not change it if i connect waveform, so i copy graphs from other VI for proper indication. But that graphs do not accept complex data. How do i change input data type?
(6,739 Views)
Well, they do for me.
Can you post a vi with those unchanging graphs?
(6,711 Views)
Found complex graph. When i connect to other two wire becomes broken
(6,694 Views)
Accepted by Dooez
The graphs in the vi you posted behave correctly on my machine.
The change according to the data type you wire to them.
Maybe something is wrong with your installation?
(6,677 Views)
You're trying to connect a string or cluster to that graph.  None of the graphs accept a string type (this should make sense).  Try the XY Graph instead for the cluster.
(6,652 Views)
