Waveform chart not responding to 'Active Y Scale' property node
I am running into a problem with using the Waveform Chart in LabVIEW 17.0 (32bit). My chart has a left and a right Y axis. I would like to programmatically assign my plots (8 analog waveforms from DAQmx) to either one of two axis.
I have created the following two property nodes with the waveform chart as reference:
  • Active Plot
  • Active Y Scale
When I set ActPlot to one of my 8 plots (between 0 and 7), and ActYScl to 0 or 1 (corresponding to the index of the left or right Y axis) the axis assignment of the plot does not change. Manually changing the axis by right clicking on the plot > Y Scale > Axisname works as expected. The waveform chart does respond to the 'History' property node. I have included a demo VI which replicates this problem.
(2,887 Views)
Accepted by Elmar123
You should be using Plot.Y Scale Index, not Active Y Scale.
Active Y scale is used to pick a Y scale and change the properties for it.
You should probably put that node in a case structure so that they don't execute all the time.  Also, since you can only change one control at a time, you wind up changing the scale of the existing control, or the plot to the existing scale, undoing whatever changes you already made for that scale or plot.
(2,874 Views)
That solved my problem, thank you!
I will make sure to put it in a case structure, I only need it to activate once before starting the measurements.
(2,868 Views)
