Wayne Kerr 3260B
Im trying to find the latest driver for Wayne Kerr 3260B.
I tried downloading the driver from http://www.waynekerrtest.com/global/html/products/woundcomponent/3260.htm,
looks like that version is too old for Labview 2011. Do we have an updated version?
Thank you,
Eureka
(3,761 Views)
Do you have the old version? I am guessing LV2011 says the Vi is too old to open.
I can up convert it as I keep LV 8 installed because we still have a decade worth of LV5.1 code floating around the company, but I did not see a download for it on their site.
There is also an Upconvert VI Requests thread where you can attach it to a post and someone will up convert it for you.
=== Engineer Ambiguously ===
(3,748 Views)
I have attached the old version, I'll post a request in the Upconvert VI Requests thread as you advised.
Thank you,
Eureka
(3,739 Views)
Accepted by Eureka
Here you go
(3,730 Views)
Wow, that seems to work...although Labview says some of the VIs are missing while i try to execute it, but i'll mess with this one for a while and see what happens...btw...was this one available online?
Thank you,
Eureka
(3,722 Views)
I took the LLB you posted and mass compiled it in LV 8.21
I noticed it was smaller after the recompile, I figured it LV 8.21 was more efficient compile then LV 5.11.
Maybe I did it wrong? See if you get a different file from the VI upconvert requests thread.
(3,719 Views)
