Web Services for a State Machine Based VI
Thank you for the reply. I received a zipped folder which included a vi called Call Functional Global Variable. This folder included another folder called Resources and in there I received the code for the functional global variable. It was my mystake to thinking that I received this from you. Sorry and I appologise.
I have received a solution which works and that uses Network Published variables between the main vi and the web services vi.
However I wanted to understand the approach you indicated but I could not get it working. Even with the Open Application Reference. I will keep on studying what you said. I understand the concept but somehow I do not implement the calling vi correctly.
Thank you again for all your help, have a nice day.
Message 11 of 12
(405 Views)
You might find the information in this thread on LAVA helpful as well: "8.6 Web service question."  There are some screenshots there of working (or very-close-to-working) code demonstrating what I suggest here.  Sorry, I no longer have a demo project put together that I can quickly share (I think the one I mentioned in that thread got left at a previous job).  You're pretty close with the last set of VIs that you uploaded, but without information about why it didn't work and what errors you saw, I can't provide much more help.
Message 12 of 12
(403 Views)
