WebDAV file info, type and last modification empty
I am using LV2013 SP1 and working to replace existing FTP functionality with WebDAV
For this task, I need to get a listing of files (*.tdms) on the RT (cRIO) and allow the user to select those for transfer.
My current FTP method displays name, date & size in a listbox for sorting and selection.
Regardless of whether I use WebDAV Synchronous or Asynchronous VIs to retreive a directory list, the file info's cluster type and last modification elements are empty.  The RT has WebDAV Server 13.5.0 installed.
I did notice that the type is populated for text files (text/plain), but last modified is still empty.
I'm guessing the MIME type of TDMS files doesn't exist?  I don't require that information for sorting.
However, the last modified information is very important for my applications & users for sorting the file list.
Could this possible be an issue with any RT settings or missing software?
Thanks for any suggestions/assistance.
James
Tech Advisor - Automation
LabVIEW 5.0 - 2020
(4,963 Views)
Hi James,
That is certainly a strange issue. Can you post up your code so that I can try to replicate the behavior?
Thomas N.
(4,914 Views)
Hi Thomas,
Thanks for the response.
You can use the NI Example Finder and enter "WebDAV" to locate the WebDAV Data Acquisition.lvproj and simply run the Windows WebDAV Sync.vi to see the problem with WebDAV Asynchronous VIs.
I decided to use WebDAV Synchronous VIs in my application, but see the same problem.
Here's the WebDAV section of my code.
Thanks for any suggestions.
James
LabVIEW 5.0 - 2020
(4,906 Views)
Hey James,
While I was researching this issue I found that you are currently working with another Applications Engineeer on a Service Request. From here it would be best to consolidate all of our effort on that Service Request. We will update this posting once we reach a resolution.
Thomas N.
(4,879 Views)
Yes, I agree.
When the root cause is identified and a solution or CAR created I can update this thread.
James
LabVIEW 5.0 - 2020
(4,868 Views)
Accepted by topic author James@Work
The issue has been assigned to CAR 513004
The problem details...
  • WebDAV Server 13.5.0 & 14.0
  • RT Targets with VxWorks
  • The NI_WebDAV.lvlib, Directory Listing.vi does not return last modification values in the FileInfo.ctl array.
James
LabVIEW 5.0 - 2020
(4,822 Views)
I hadn't thought about this thread in a long time, but this bug (CAR 513004) was corrected with the release of LabVIEW 2015; Release Notes.
LabVIEW 5.0 - 2020
(4,479 Views)
