Weight gauge serial port test
Yes, but as far as i know, i'm going to write my commands, and read it after in the test panel, but i always get that error:
"Timeout expired before operation completed" during reading process
Best regards
Oesen
Message 11 of 17
(1,090 Views)
And as far as we know, you could be writing gibberish. Explain exactly what you are writing. Better yet, attach an image.
Message 12 of 17
(1,085 Views)
Hello. Sorry, i was inactive for some days. But im writing those commands from the manual, and reading it after
Best regards
Oesen
Message 13 of 17
(1,061 Views)
That image is just about unreadable but it looks like your command string is *IDN?. Your list of commands does not show *IDN? so why would you want to send that?
Message 14 of 17
(1,059 Views)
Yes.. Im sending it as *IDN. What should i else send ?.. Sorry my serial port cable is in workplace, so i can't open the test panel right now
Best regards
Oesen
Message 15 of 17
(1,047 Views)
You have to send commands that are supported by the instrument! You can only send what is listed in that table. You just can't make things up and expect a response. You also cannot do a read when the instrument does not send anything back. You also have to terminate each command with a \r\n (CR\LF).
Message 16 of 17
(1,041 Views)
I have connected my pins from RJ45 to the D25 RS-232 cable as show in the picture above
And im writing the command "DN" which resets the weight display:
As shown in the picture below:
Anything wrong with that procedure ?
Best regards
Oesen
Message 17 of 17
(1,025 Views)
