Well This is Annoying (Cluster Autosizing)
Put an instance of the attached typedef on a FP.
Reduce the heights of the sliders.
Change the cluster autosizing to "Size to Fit"
It doesn't work properly; it sizes to the original in the TD.
(1,338 Views)
I don't know if this is the full solution, but when messing around with your type def, I noticed that if I made the slider's "text display" visible, it is located under the main slider graphic.  This may be forcing the cluster frame to be longer than it needs to be, even when that element is normally hidden.
You may be able to adjust the slider's text display indicator position on the original type def, or just remove it altogether.
edit: spelling
(1,320 Views)
edit: spelling
Nice try, but no cigar.
(1,275 Views)
If I make all 4 "Text display" boxes visible, then hide them all, it seems to behave as expected afterwards.  Still weird...
(1,261 Views)
This is really strange.
After reducing the size of the 4 sliders, I set the cluster size to "Arrange Vertically" and "Arrange Horizontally" to see what happens and I was quite surprised that this empty space also appears in these cases.
The behaviour remains the same even after "Disconnect from Type Def.". This surprises me even more.
PS : LV 18 SP1
(1,224 Views)
