What does this message mean ?ni compactrio driver support for labview 2015 is missing
If you have the driver problem, how did you then make a test for the I2C?
To run any code on the myRIO you need the driver, so I don't really understant your problemes.
Message 21 of 25
(1,981 Views)
Hi!
So its more likely a module problem maybe?
I have now connected the motoboard H bridge / two motors  and the gyro board.
The first message is not longer I2C therefore I was thinking that problem was solved and it had to be the gyro as you suspected.
The fault message i get is identicall to the first post i added to this forum tread.
Message 22 of 25
(1,968 Views)
Anyone here that has the 2015 version myrio ?
That is able to open this project https://decibel.ni.com/content/docs/DOC-34547  myBOT-V1.zip(3.7 MB)  without any fault message of missing toolkits, driver?
If so it would be great if you could post a picture of MAX that shows all installed drivers and toolkits.
I have deleted my 2015 verson for the third time , and have just finnished installing the 2015 myrio dvd bundle  1 and  2 dvd that contains drivers and toolkits once again .
But once again i get the same fault message.
Message 23 of 25
(1,935 Views)
Where did you installet it?
It seems like you installed LabVIEW on you D drive?
It could also be that the RoboRIO vi that is listed, has a worng link to find the right module?
Have you tried to open the vi in the picture and save it?
If youy are able to start a plain myRIO project, or one of the sample projects for the myRIO, then it is not a driver issue.
And then there is no point in installing every thing over and over.
And be the way, it is not an error that shows up, only a warning.
Have you tried to save the project after you have opened it?
Have you tried to run the main vi ?
Have you tried to build the vis for the myRIO?
Message 24 of 25
(1,930 Views)
Update!
The erro code is gone after installing 2013 version.
Added a picture here of what software/ drivers that has been installed.
Thanks for all replys.
Message 25 of 25
(1,876 Views)
