What is going on with my text ring?
I am trying to make a text ring with the values 1, 2, 5, 10, 20, 50, etc.. all the way up to 100,000. The strings associated with these values are 1 kHz through 100 MHz. When I click on the text ring, I can see all the values in both the MHz and the kHz, but when I select a value in the kHz, it sets itself back to 100 MHz, and when I try to go one higher than 1 MHz, it returns to 100 MHz. I have no idea what is going on.
(2,743 Views)
Please post your vi in 2009 version or 2011
(2,738 Views)
Here is the version saved for LabView 8.6. Same behaviour.
(2,732 Views)
Accepted by CatherineH
Expected behavior.
You configured the minimum to 1000.0000 as coerce. You have to change this in the data entry tab of the property dialog.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,731 Views)
