08-05-2011 11:42 AM
post your code
08-05-2011 11:50 AM
08-05-2011 11:54 AM
Its to keep us guessing.
Usually they are guessing on how to program and it wouldn't really be fair to have both the code and someone who knows how it works in the same location. That would just be too easy!
08-05-2011 12:01 PM
The picture shows how the the values are all the same even though they are pointing to the right termal couple
08-05-2011 12:05 PM
Password Protected ![]()
08-05-2011 12:33 PM
SORRY ABOUT THAT TRY THIS ONE
08-05-2011 12:38 PM
Also, don't post a bitmap image and just call it a jpeg by renaming the file to get around the forum's file filters. Changing the file extension doesn't magically turn it into a jpeg. It is still an unnecessarily huge bitmap.
You should save it as filetype .png to get the best filesize and also get an image that is very true withoug compression artifacts.
08-05-2011 12:41 PM
I liked your VI better when it was password protected. All I got to work with is a DAQ Assistant with no configuration.
