Where does LV 2009/2010/2011 save the last used folder?
Hello, where does LV2009/LV2010/LV2011 save the last used folder? I need all three versions on my development computer and when i open a project e.g. in LV2010 the folder is "e:\LabVIEW Data 2010\Projects\Project A\". Then i close LV2010 and open LV2011 and when i click on "open" LV2011 starts in the last folder from LV2010 and NOT in my standard data dir "e:\LabVIEW Data 2011\" The same from LV2011. When i open a project in 2011, LV2010 will start in that from the LV2011 project. I believe that the information is stored inside registry HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\BagMRU Regards Stefan
(3,404 Views)
I'm fairly sure that this is a windows feature to save the folder.
What do you need this information for?
Best reagrds, Stefan Wimmer
(3,358 Views)
Is it you who asked the same question a few days ago? If yes, please try to keep 1 thread per discussion so we don't lose history.
There was an MRU option in LabVIEW, there no longer is... having the feature you descibe would be nice, I suggest you place an idea on the LabVIEW Idea Exchange and then tr and get people to vote for it so it might come in next LV version.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,354 Views)
Accepted by mniedernhuber
I found a solution that works for me (didn't find any disadvantage up to now)
Original i have these files:
c:\Program Files (x86)\National Instruments\LabVIEW 2010\LabVIEW.exe
c:\Program Files (x86)\National Instruments\LabVIEW 2011\LabVIEW.exe
and the labview.ini files.
I have renamed these file as:
c:\Program Files (x86)\National Instruments\LabVIEW 2010\LabVIEW_2010.exe
c:\Program Files (x86)\National Instruments\LabVIEW 2010\LabVIEW_2010.ini
and
c:\Program Files (x86)\National Instruments\LabVIEW 2011\LabVIEW_2011.exe
c:\Program Files (x86)\National Instruments\LabVIEW 2011\LabVIEW_2011.ini
Now the MRU distinguish between two different EXE Names and it works perfect up to now...
If i have any problems i will post that here.
(3,332 Views)
Idea Exchange: Save Last Used Folder (MRU)
Please Kudos 🙂
(3,303 Views)
