Where is the Function"Open File+.vi"
Hello: Where is the Function"Open File+.vi",I can't find it in Labview function lib. Please help me where it is ?Thank you
Message 1 of 8
(4,659 Views)
Why do you have this question?
Is it that you are working through a workshop which instructs you to look for this vi? Is it because you have a code where this vi is missing?
I am not aware of any "Open File+" vi in standard LV, so i guess it is part of some additional library which was used when creating another vi.
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(4,654 Views)
Hello Norbert: yeah ,i have a code where this vi is exist. and I try to use this vi ,which is very good. So i want to use this "Open File+.vi" when i program next time . but i don't know where it is from?do you have way to find this vi hide path ?
Message 3 of 8
(4,649 Views)
When you load the calling VI, there should be a search dialog. What is the path it initially looks into?
If you cancel the dialog and open the block diagram, the VI will show with a big question mark. Open the context help and check the expected path there. It is possible that you have to press the bottom left button (show/hide terminals and full path) in the context help window before seeing the path.
Where does this path point to?
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(4,645 Views)
i find path: C:\Program Files\National Instuments\LabVIEW 2013\vi.lib\Utility\file.llb\Open File+.vi 。 is it a additional liabray "file.llb"?
Message 5 of 8
(4,632 Views)
Accepted by shawn1
What version of LV are you using?
In LV 2015, i indeed find that vi in the file.llb under the stated path (LV 2015 instead of 2013 of course).....
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(4,627 Views)
HaHa,Thanks for your Instruction
Message 7 of 8
(4,620 Views)
In general though, either check the General tab of a VI's properties, or r-click the file in the project windows and select "Explore ..."
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,587 Views)
