Where to find the path function
Ok newbie stupid question where in the heck is the Path function, I have it labeled as Log File and more than likely I probably got tired of trying to find it an copied it from another VI. I would have thought it would be under the File IO but I can't find that little icon anywhere?
(4,895 Views)
I couldn't view your VI but most path functions can be found around here:
You can also press ctrl+space and type in the name.
(4,885 Views)
Accepted by rr1024
Thanks, I think I figured it out, I had to go to the front panel in string paths, but I would have thought you couple place it from either front panel or block diagram.
(4,877 Views)
I see, controls and indicators can only be placed on the front panel. Sometimes you can drop a constant down and right click it to change it to a control or indicator though.
(4,872 Views)
Good to know, thanksSmiley Happy
(4,869 Views)
