While loops
I have to read and write data. Is it possible to put them in one while loop or I need to separate them?
Message 1 of 34
(2,729 Views)
Hi alhabeeb,
You can put anything inside a (while) loop…
How you organize your VI (aka which algorithm you need to implement) should be dictated by your requirements!
So what are your requirements???
Message 2 of 34
(2,728 Views)
The depends on whether you expect a Write/Resonse or the target publishes automatically all the time ...
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 34
(2,686 Views)
I have two heaters that need to be controlled (on/off) by using ni-9475 which generate voltage (digital signals)  according to set temperature point and measured temperature, as shown in the lower part of the while loop in my attached VI. Is my code good like this or need to be improved?
Message 4 of 34
(2,663 Views)
For a DAQ system, I have the Analog Input be its own loop. It can then use a queue to send the data to another loop for processing and logging.
Also, the Digital Output tasks do not need the timing. You can just remove the DAQmx Timing VI from those tasks and they will be static/software timed.
Message 5 of 34
(2,659 Views)
While you have implemented many of my earlier suggestions, you still have completely unnecessary complications, for example your small case structures are equivalent to a wire, right?
Also, the total time does not need to go through the case structure because it is just wired across in both cases (Yes, the compiler will simplify it behind the scenes, but code should be clear and things that don't depend on the case, should not go through the case structure for code readability!)
Why do both heater physical channels have the same default value? Why are most other channels blank by default?
Why is the front panel so disorganized? etc.
Message 6 of 34
(2,641 Views)
Thanks! It is done.
Message 7 of 34
(2,593 Views)
Yes, you are absolutely right.
Yes. it is done!
Yes, it has been modified.
Yes, I agree. I will organized it more when I finish all other improvements.
Is there any other suggestions?
Message 8 of 34
(2,591 Views)
I aquire 0 values of Al Current, why?
ALHABEEB
Message 9 of 34
(2,572 Views)
I figured it out but it kind of a mess because I need to convert the current to mass flow rate by this formula
Flow Rate=(Measured Current_mA4mA)/16mA.
Any way to organize it more?
ALAHBEEB​
Message 10 of 34
(2,542 Views)
