Why column data of a database table is not getting updated in each iteration?
Here is a simplified layout.  I changed it up to build the cluster in the frame loop.  And I just realized that I didn't convert the coordinates to a string before inserting into the cluster.  Unfortunately I don't have time to correct it right now but you should know how to do that from the previous posts.
aputman
Message 11 of 14
(698 Views)
Thank you again. I will check with that.
Message 12 of 14
(696 Views)
I have changed my code by building an Array of Cluster for 'Color thresholds ' for each particles. But, when I run the VI the VI doesn't get executed after 'IMAQ Color Threshold.VI' i.e the frames of AVI doesn't get thresholded. It throws an error at probe 12 as below:
error -1074396120 occurred at IMAQ ColorThreshold
Possible reason(s):
IMAQ Vision:  Not an image.
Can you suggest why it is happening that way?
Message 13 of 14
(682 Views)
Sorry, I am not familiar with IMAQ.
aputman
Message 14 of 14
(669 Views)
