Why doesn't VISA Read read all the available and commanded bytes
Hi All,
I am using VISA Write.vi and VISA Read.vi to send and receive byte packets to and from a processor.  Usually everything works fine.  I set a loop to repeat until it sees at least 20 bytes at the port, then I VISA Read to read 20 bytes.   However, when I receive certain byte packages, my property node shows 20 bytes at the port, I instruct VISA Read to read 20 bytes, but it only reads 13 bytes and leaves seven bytes at the port.  If I run the read operation again, it will read them remaining 13 bytes.
Any ideas as to what could be making this happen?
Forbes
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,017 Views)
Aha!  Any time VISA Read sees a "10" as the value for one of the bytes, it automatically stops reading at that point.  I'm guessing there is a property setting I can find to tell it not to do that.  Any help would be greatly appreciated.
Forbes
Forbes Black
(3,005 Views)
Accepted by diarmaede
OK, I figured it out.  I set "Enable Termination Character" in "VISA Configure Serial Port" to "False," and all my problems disappeared.
It's fun talking to myself.
Cheers,
Forbes
Forbes Black
(3,004 Views)
Glad we couldn't help. Smiley Very Happy
(2,996 Views)
