Why dos my VI pause? And have a red
Im relatively new to labview (8.0) ...  And my communications sub VI is acting funny at the moment.
The sub VI executes correctly, but it has a red boarder around (it's block diagram).  When the VI has fully executed my program pauses and the boarder flashes red to blue.  When I unpause it the program continues as normal.
I have not added a breakpoint, and I cannot think of what else may be causing it.
If anyone has any ideas I would be in your debt!!
Thanks a mil
C
(2,832 Views)
It seems that you have unadvertently set a breakpoint on the block diagram (it is rather common when clicking above a threshold frequency Smiley Wink). Simply remove it by clicking on the b.d, with the breakpoint tool.
Paolo
(2,818 Views)
I dont think so...
Thats wat i thought initially so I went >
> Operate
                  > Breakpoints
And set search scope to "All VIs in this application instance", I also searched but the sub VI and the Top Level VI separately.
The search returns no breakpoints, so ive ruled that out.
Any other ideas???...
(2,813 Views)
This behavior is exaclty the same of a block diagram breakpoint, so if you are sure that none was set, the vi may be somewhat corrupted.
Try to unblock the situation by setting/unsetting yourself a breakpoint (every time saving the vi and re-opening), or saving for version 7.1 and re-opening, or copying all the block diagram to a new vi (if possible).
Paolo
(2,807 Views)
