This behavior is exaclty the same of a block diagram breakpoint, so if you are sure that none was set, the vi may be somewhat corrupted.
Try to unblock the situation by setting/unsetting yourself a breakpoint (every time saving the vi and re-opening), or saving for version 7.1 and re-opening, or copying all the block diagram to a new vi (if possible).
Paolo
LV 7.1, 2011, 2017, 2019, 2021
